The little 358 sounded sweeter at 9,500. 358 sounded noisy until it reached 7,500. A real loose bottom end used in NASCAR.
The 440 is standard firing order and relatively calm and quite. It was a little rough at part throttle but, like I said the plugs are pretty bad and the tune has gotta be out a little.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
