first problem I see is the TBI throttle pedel/cable is different than the 85 truck.
not sure what the fix will be at this time. the 85 has a square hole in the firewall and the 91 has a round hole.
not sure what the end of the tbi cable looks like, it was cut and MIA
hey Mike, been out of town and haven't read far enough to see if you figured this out. when I did my V8 swap, I ran into the same thing. The '88 had a different pedal and cable set up than the '87 donor. The holes for the cable were different holes like yours. I stuck the round cable from the '87 in the square hole( or was it the other way around..?) and it's worked fine for three months.
