it was much ez-er install with rear axle in the back of truck on jack stands. it takes some fiddling with it to get it all together and in place. lot tuffer under the truck with gravity working against you installing the c-clips.
first time I heard it, i thought it broke something, it does make some noise but MAN! does it lock them together
