last 3 trucks Ace has sprayed,he used the rustoleum rubberized spray bed liner.
same finish look you have there in the raptor.
the 64 chebby got it in the lower cab with a gloss white dash and upper 1/2 of cab.
the 59 chebby got same inside with a full undercoating and all of the underhood/engine bay.
what was a fast patch up to swap in the 5 speed is turning into a little more body work than i had thought about doing.
but I am really enjoying the project again for a change.
I am ready to flip the cab and weld up the bottom next,then on to sparying the bedliner.
