Quote: I'm wondering if the tall "gusset" around the ball joint on the UCA would limit rim offsets and diameters?
I do not think this will be an issue. It is not designed with only large diameter wheels in mind. Have to remember this set-up is intended to cross over between street, drag and Pro-touring applications. Obviously wheels sizes wheel vary.
I can get some visual clearances posted here once I can get to that point in the install.
