Okay, I read the tuning page there again and if I'm reading it correctly, it states to check the throttle plate relationship if you have a lean condition causing a stumble and off-idle hesitation. Then it recommends checking the float levels and then the power valve for an excessive rich idle situation. I've been wondering if that could have anything to do with my power brakes not feeling exactly right??? How do I vacuum check the power valve?.....Thanks
