Thanks Jim, I'm pretty sure the timing is right, or VERY close to where it needs to be. I had a good engine builder/tuner put everything together and I know for sure that the timing has been advanced (hence the tape in place, etc). I'll get a reading on it either way and report back. So, just a basic timing light right? Just hook it up and check it while idling normally in park?....Thanks
