Quote: We might be getting ahead of ourselves. Let's check the basics before we fix the carb.
How many cubic inches is this engine? Camshaft duration @ .050"?
What's going on with the ignition timing? What's your static timing and what's the total advance?
Mild 360 with CompCams XE-268 224 @.050 approx. 10:6:1 compression with box-stock Edelbrock Heads. not sure what the timing is, balancer is marked withe the timing tape, I just need to get a timing light to see exactly where it is. Engine is basically a fairly mild 360 with a good MP convertor and gears. Carb is just VERY rich, more so than it should be, even after re-jetting. Thanks for all the help guys....
