Hey out there,
Just received my ss700, #63 for b body...
Unit looks heavy enough, and a clean design...
Here's what I see right out of the box, I'll start with the negatives...
1) the pilot for the throw out bearing is too big to fit a stock 2892626 bell housing and will have to be machined down...
2)the transmission bolt pattern doesn't line up with this housing either, though there is plenty of stock to put the holes in the correct positions...
3) the hole patten is for a tremec, ( I have a modified bb bell housing)...
4) aside from the 21 months of bs from keisler, My opinion, they are quick to get a sale get your money then will give the any reason why your trans doesn't ship...
For the positives...
1) doesn't look like I'll have to hack up the tunnel of my Coronet...
2) the modifications appear easy if you have access to a machine shop...
3) trans has Legend on the case, NOT "keisler"...
not a fan of them if you can't tell.
will post more when I start the install, probably a month or two...
Regards Tim
