I have some other (later) power steering pumps, that I may see if I can get to work before I start grinding metal. I also have a bigger radiator out of a 1969 coronet AC car. I am going to see it I can get that to work as well.
Everything on this motor is the 1969 stuff. The only things changed on the outside is the heads, valve covers and intake. This swap may be easier if I had other timing covers, brackets, etc?
I knew this would be a learning experience.
However, today it is 34 degrees outside with a 20mph wind, and I don't have a garage....so....it may have to wait until my next day off!
eightlitermopar
