Here is the pump installed. The attached steel line in resting on the "trouble spot" in the picture. At this point, the pump needs to go down. It is sitting to high for the belt adjustment at this point.
thanks for the pics,they are worth a 1000 words.
I notice you have the early T-cover/WP/PS pump
maybe this is why others do not have a fitment issue with the PS pump.
are the early and later model non a/c brackets different?
either way,after "seeing" the issues it is much more clear as to what I would need to do. thank you.
