According to some earlier posts on this website, it's possible to redrill the magnum heads to use the LA intake manifold. If I recall correctly, the ports in the LA intake are a slightly different size or shape than the ports in the magnum heads. Because of this difference, it's best to use the aftermarket intake designed for the magnum heads.
