Its been discussed before and the consensus (last I checked) was that the separate tube (not the floor contoured connectors) were the strongest option.
Can't comment on the weld the k-frame idea though. In theory it should work. But I've also changed small block pans with then engine and K in the car just by lifting the engine off the mounts a bit. Not sure if the Big Block pan has any other caveats to it...
