Re: Lets See Your Trucks
[Re: Magnum]
#29865
12/22/06 12:32 PM
12/22/06 12:32 PM
seats are a '97,
Like to hear more about your 97 seat install 85 Beast. We should start a new thread for interior. What did you do for seat belts?
Magnum... The seat install was pretty easy...I don't remember for a fact, but I think I used a couple of the stock mounting holes. The others I just drilled out. At the time I was in a hurry, so I used 3" pipe spacers from Home Depot to make the difference from not having a level floor. I wasn't able to mount the center of the seat since the holes ended up right on top of the transfer case...but there has never been a problem with the seat shifting at all. For the seatbelts, those are also from a '98, and I just bolted them in the stock locations. If I ever re-do it, I think I would go with the newer style seats that have the integrated seatbelts.
