Just a short useless boring update. The rear wheel wells were rotten but repair panels are either not available or expensive, thinking outside of the box it turned out that early C10 are very close to the same profile and cheap. Only a purist might be able to see the difference.
Turns out that my stubbornness and cheapness backfired, ... the diff is to wide and the wheels to big and I could not remove the wheels. So, plan "B", an added on latter model C10 panel. Cheap. Not so stock looking now.
