It doesn't help that I don't have a wiring diagram for a 91 Dakota,
The mixing and matching is the kind of trouble I am trying to avoid.
Gene, I think I have a 92 shop manual, I could scan the pertinent wiring diagram page if it would help?
Old Ray, at this point if I can get a pin out for the rear body harness plug at the firewall for the 92 Dakota, that would help. The 87 didn't have a connector there, and that would save me from undoing all the wiring to the rear of the truck.
I've pretty much decided I needed to start at the fuse box and wire everything from there. I have most of the circuits laid out, its just a matter of getting everything in the right place and splice a bunch of wires. Gene
