Dakota sub-frame to '56 plymouth frame splice with paint. Took much longer then expected (of course), welds not close to perfect but will do, rolling on the floor not easy for this old turd.
Question: Do you think two coats of paint will make for a stronger join ?
Yes! Two coats of paint will keep the rust at bay better then one coat of paint (and it looks better too), and one coat of paint is much better then no paint (unless you paint like I do). Gene
