Why run a steady bearing? Why not just a one piece driveshaft? How long is the overall length?
The internet (so it must be right, right?) says anything over 54 inch should be two piece, which I would have ignored, but the two piece was out of the donor Dakota and because the engine/trans sits high I think the extra u-joint helps spread out the downward angle (kind of like some 4 x 4 drive shafts.
