Chain tension has nothing to do with it. The pointer is not connected to the chain, the balancer is not connected to the chain either.
The main objective I need is to find out whether the 0 mark on the timing cover is indeed TDC. I guess I can see detecting whether the balancer has slipped by utilizing another point.
I appreciate all your help!
Is there any possible way that I can utilize a 3/8" fuel line to detect TDC?
Only if it is solid, will not crush, and will not move when you crank the motor over.
here is picture of a spark plug piston stop. From Comp cams
$8.95 but I would use a locknut on it while using it.
Summit sells one. Just remember to hand crank slowly.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
