Yes the TDC tool is cheap/simple. put your marks at 5BTDC, screw it in until it firmly contacts the piston, with a breaker bar turn crank CCW until it contacts the piston & it should be at 5ATDC. I also put a plastic vac cap(one of those 5 cent colored rubber ones) on the end to keep from(potentially) nicking the piston. Balancers do not slip very often. What is your situation?
