Has decent pull but still struggles getting up to 7K even more going from 2nd to 3rd.
That is straight thinking to K.I.S.S. & go thru the basics & I am guessing here but with that symptom I would want to check my fuel psi as I go thru the traps & see if I have at least several lbs of pressure. It could be valve float & ign issues which would show up at a certain high rpm(in any gear) as the load would pretty much be the same in 1st as in 2nd but for it to act differently in 2nd is making me think fuel starvation but I am out on a limb here. Stay in touch
