Re: 440 daily driver (550 hp, 600 ft-lb tq)
[Re: fast68plymouth]
#2566580
10/19/18 05:30 PM
10/19/18 05:30 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
This is the same 440 with the cam I run in my street car 512 cid Hyd roller. Surprising for me to see the cam in your 440 made more HP than in your 512. I D/Led Dyno 200, trying to bumble through it now. Heh heh heh........ You’ve just discovered the big flaw that’s in many engine building simulation software programs. I built a 446 and a 493 that were very very similar to each other besides the displacement. On several engine sims the 446 showed higher output. On the real dyno the 493 was clearly better...... and not by a small amount either. Yep I have found the same as you on my old dyno, was trying to show the rpm difference ,same cam & more cid. & as you know it is just a Sim.:)
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
Entire Thread
70charger512
10/19/18 12:01 AM
Pacnorthcuda
10/19/18 12:22 AM
70charger512
10/19/18 12:31 AM
Pacnorthcuda
10/19/18 12:29 AM
70charger512
10/19/18 12:35 AM
Spaceman Spiff
10/20/18 01:50 AM
Pacnorthcuda
10/19/18 12:47 AM
70charger512
10/19/18 01:49 AM
SomeCarGuy
10/19/18 02:13 AM
70charger512
10/19/18 02:37 AM
SomeCarGuy
10/19/18 05:07 AM
70charger512
10/19/18 05:26 AM
70charger512
10/19/18 03:18 AM
Skeptic
10/19/18 03:52 AM
70charger512
10/19/18 05:27 AM
BradH
10/19/18 03:43 AM
SomeCarGuy
10/19/18 05:29 AM
70charger512
10/19/18 05:54 AM
SomeCarGuy
10/19/18 08:56 PM
Pacnorthcuda
10/19/18 05:35 AM
70charger512
10/19/18 05:59 AM
Pacnorthcuda
10/19/18 06:55 AM
70charger512
10/19/18 07:05 AM
Thumperdart
10/19/18 05:46 PM
Pacnorthcuda
10/19/18 06:58 AM
CSK
10/19/18 07:07 AM
Pacnorthcuda
10/19/18 07:16 AM
CSK
10/19/18 07:17 AM
Pacnorthcuda
10/19/18 07:09 AM
CSK
10/19/18 07:12 AM
65Fury440
10/19/18 03:25 PM
fast68plymouth
10/19/18 08:54 PM
CSK
10/19/18 09:30 PM
383man
10/19/18 07:17 AM
AndyF
10/19/18 07:23 AM
CSK
10/19/18 07:23 AM
70charger512
10/19/18 05:32 PM
polyspheric
10/19/18 02:23 PM
70charger512
10/19/18 05:20 PM
73DAD
10/19/18 03:05 PM
dwayne welder
10/19/18 03:26 PM
TonyS451
10/19/18 05:20 PM
70charger512
10/19/18 05:26 PM
70charger512
10/19/18 05:23 PM
AndyF
10/19/18 05:41 PM
ZIPPY
10/19/18 09:25 PM
BSB67
10/20/18 12:06 AM
ZIPPY
10/20/18 01:37 AM
ZIPPY
10/19/18 09:35 PM
TonyS451
10/19/18 09:56 PM
ZIPPY
10/19/18 11:22 PM
GY3
10/20/18 12:54 AM
Cab_Burge
10/20/18 02:10 AM
Thumperdart
10/20/18 02:33 AM
70charger512
10/20/18 02:34 AM
ZIPPY
10/20/18 05:02 AM
Diplomat440
10/20/18 04:03 AM
viperblue72
10/20/18 04:14 AM
65Fury440
10/20/18 05:24 AM
Cab_Burge
10/20/18 08:06 AM
70charger512
10/20/18 04:46 PM
Cab_Burge
10/20/18 05:25 PM
70charger512
10/22/18 02:50 PM
MR_P_BODY
10/22/18 03:05 PM
70charger512
10/22/18 03:11 PM
MR_P_BODY
10/22/18 03:18 PM
moparx
10/22/18 04:07 PM
MR_P_BODY
10/22/18 04:31 PM
67Satty
10/22/18 08:58 PM
70charger512
10/22/18 11:58 PM
BradH
10/23/18 12:52 AM
70charger512
10/23/18 03:48 AM
BradH
10/23/18 01:18 PM
70charger512
10/23/18 02:45 PM
an8sec70cuda
10/22/18 09:46 PM
70charger512
10/22/18 11:54 PM
an8sec70cuda
10/23/18 02:34 PM
70charger512
10/23/18 02:44 PM
ZIPPY
10/23/18 02:41 AM
BradH
10/23/18 03:39 AM
CSK
10/23/18 04:04 AM
70charger512
10/23/18 06:18 AM
65Fury440
10/23/18 06:21 AM
dOOc
10/23/18 06:41 AM
Cab_Burge
10/23/18 09:08 AM
radar
10/23/18 03:44 PM
radar
10/23/18 04:02 PM
krautrock
10/23/18 04:08 PM
