Originally Posted By Cab_Burge
Originally Posted By 65Fury440
Not sure if anywhere in this mess it was communicated that a 500 CI stroker will eat duration. The cam that might have a 3400- 6500 operating range in a 440, might drop maybe by 1000rpm in a 500 CI.
When you have big cubes,you will have more torque than you need.
You also will get a lot more need for good traction and unbreakable drive train parts work shruggy Trust me on this, been there, done that whiney shruggy
Of course lol, drag radials for the track (not slicks because i have to drive it there), caltracs, dana 60, dennys hd steel driveshaft? That should be a strong enough driveshaft right? Or should i get the nitrous ready?
