Re: 440 daily driver (550 hp, 600 ft-lb tq)
[Re: Pacnorthcuda]
#2566126
10/18/18 08:31 PM
10/18/18 08:31 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Nick, as you know, I run the Lunati 60303 cam
440 .030 over Oob Stealth heads .017 below deck, Cometic .027 gaskets for quench 10.2 Compression ratio Eddy RPM Holley 850 DP Headers
833 4 speed, 3.55 gears, 28 inch tires.
Cam was degreed, came in at 106.75. (Was supposed to be 106). I ran it that way for a year or so then advanced 2 degrees to 104.75-----I was bored, don't get too caught up in this detail.
I can pull away from a stop at 1000-1500 rpm as long as I'm light on the throttle until 1900 rpm, then full throttle is OK (and of course will fry the tires).
What I CANT do is pull away from a stop at less than 1900 under moderate or heavy throttle----if I do the engine will lug. It's all about split second timing of the clutch vs throttle--that's all.
Similarly, I can cruise in 3 or 4th gear at 1500rpm, as long as throttle is LIGHT--if I want to accelerate from this condition I either stay gentle till 1900, or downshift. Thank you for your reply, and thats why i wanted the 60303 cam, but was told it will limit my numbers well below the 550 hp mark. What are you making?
Entire Thread
70charger512
10/19/18 12:01 AM
Pacnorthcuda
10/19/18 12:22 AM
70charger512
10/19/18 12:31 AM
Pacnorthcuda
10/19/18 12:29 AM
70charger512
10/19/18 12:35 AM
Spaceman Spiff
10/20/18 01:50 AM
Pacnorthcuda
10/19/18 12:47 AM
70charger512
10/19/18 01:49 AM
SomeCarGuy
10/19/18 02:13 AM
70charger512
10/19/18 02:37 AM
SomeCarGuy
10/19/18 05:07 AM
70charger512
10/19/18 05:26 AM
70charger512
10/19/18 03:18 AM
Skeptic
10/19/18 03:52 AM
70charger512
10/19/18 05:27 AM
BradH
10/19/18 03:43 AM
SomeCarGuy
10/19/18 05:29 AM
70charger512
10/19/18 05:54 AM
SomeCarGuy
10/19/18 08:56 PM
Pacnorthcuda
10/19/18 05:35 AM
70charger512
10/19/18 05:59 AM
Pacnorthcuda
10/19/18 06:55 AM
70charger512
10/19/18 07:05 AM
Thumperdart
10/19/18 05:46 PM
Pacnorthcuda
10/19/18 06:58 AM
CSK
10/19/18 07:07 AM
Pacnorthcuda
10/19/18 07:16 AM
CSK
10/19/18 07:17 AM
Pacnorthcuda
10/19/18 07:09 AM
CSK
10/19/18 07:12 AM
65Fury440
10/19/18 03:25 PM
fast68plymouth
10/19/18 08:54 PM
CSK
10/19/18 09:30 PM
383man
10/19/18 07:17 AM
AndyF
10/19/18 07:23 AM
CSK
10/19/18 07:23 AM
70charger512
10/19/18 05:32 PM
polyspheric
10/19/18 02:23 PM
70charger512
10/19/18 05:20 PM
73DAD
10/19/18 03:05 PM
dwayne welder
10/19/18 03:26 PM
TonyS451
10/19/18 05:20 PM
70charger512
10/19/18 05:26 PM
70charger512
10/19/18 05:23 PM
AndyF
10/19/18 05:41 PM
ZIPPY
10/19/18 09:25 PM
BSB67
10/20/18 12:06 AM
ZIPPY
10/20/18 01:37 AM
ZIPPY
10/19/18 09:35 PM
TonyS451
10/19/18 09:56 PM
ZIPPY
10/19/18 11:22 PM
GY3
10/20/18 12:54 AM
Cab_Burge
10/20/18 02:10 AM
Thumperdart
10/20/18 02:33 AM
70charger512
10/20/18 02:34 AM
ZIPPY
10/20/18 05:02 AM
Diplomat440
10/20/18 04:03 AM
viperblue72
10/20/18 04:14 AM
65Fury440
10/20/18 05:24 AM
Cab_Burge
10/20/18 08:06 AM
70charger512
10/20/18 04:46 PM
Cab_Burge
10/20/18 05:25 PM
70charger512
10/22/18 02:50 PM
MR_P_BODY
10/22/18 03:05 PM
70charger512
10/22/18 03:11 PM
MR_P_BODY
10/22/18 03:18 PM
moparx
10/22/18 04:07 PM
MR_P_BODY
10/22/18 04:31 PM
67Satty
10/22/18 08:58 PM
70charger512
10/22/18 11:58 PM
BradH
10/23/18 12:52 AM
70charger512
10/23/18 03:48 AM
BradH
10/23/18 01:18 PM
70charger512
10/23/18 02:45 PM
an8sec70cuda
10/22/18 09:46 PM
70charger512
10/22/18 11:54 PM
an8sec70cuda
10/23/18 02:34 PM
70charger512
10/23/18 02:44 PM
ZIPPY
10/23/18 02:41 AM
BradH
10/23/18 03:39 AM
CSK
10/23/18 04:04 AM
70charger512
10/23/18 06:18 AM
65Fury440
10/23/18 06:21 AM
BeEtLeJuIcE !
10/23/18 06:41 AM
Cab_Burge
10/23/18 09:08 AM
radar
10/23/18 03:44 PM
radar
10/23/18 04:02 PM
krautrock
10/23/18 04:08 PM
