Im curious as to what the Moroso calculator says my car makes. I did'nt put my motor on an engine dyno, but I did put it on a rear wheel dyno (Dynojet) after I put the motor in the car. It's a 12 to 1 408 with ported Indy 360-1 heads, solid flat tappet cam(278/288 @ .050 with 640/619 lift on 112 lobe separation), Indy intake, 975 CFM race deomon carb. Car made 480 RWHP and is about 3250 lbs with me in it. Its run a best of 6.53 @ 104.7 with a 1.42 60'in the 1/8th.
6.53 1/8 = 10.20 1/4 =555hp at 3250 pounds
for the moroso speed calculater
1.39 9.85 - 137 mph
