if you need to for whatever reason be sure to wrap the splines in past the seal with some brown grocery sack paper BEFORE you pull the splines out past the seal. Holler if needed
I'm not clear on this Robert. Are you suggesting pushing paper through the seal before sliding the splined portion of the axle out?
