Art if it is the bearings just needing greased, the needle attachment for your grease gun works the best. No need to pull the axle all the way out but if you need to for whatever reason be sure to wrap the splines in past the seal with some brown grocery sack paper BEFORE you pull the splines out past the seal. Holler if needed
