Next up was the good old fashioned Autocross, and the only change I had made were two new rear 275/35/18 Bridgestone RE71R to match the two used ones up front. It was extremely hot (105 degrees) and the car was pushing, which I hadn't felt before. I figured out after my last lap I should have switched the new tires to the front, which I did the next day for the big track and it felt much better. Opportunity to finish top 10 lost, I was 12th out of 32...
