Yes the Hemi is tumble ports, something a lot harder (but possible usually at the expense of flow) to achieve with a wedge.
I also seem to keep seeing guys building the new hemi are claiming no difference firing both or only one plug, what have you found?
When you think about it--How can there be the same timing lead required when you have 2 plugs on opposite sides of the chamber? J.Rob
I know it makes sense but every thing I keep reading they say it don't make no difference on dyno or track even read about the guys developing it said it did not make more power but was done for emmissions I was curious if you had tried any with or without and what you found? Only reason I can think of to not change it is they are in really good locations already and the difference is too small to tell
