Brian,
have you any idea how these heads compare to the CNC Stealths ?
I think it is great there is a company stepping into the ring for Mopar , will maybe bring the others up a step with competition .
As said before the BB market is primarily 450-510ci making to 650ish HP .You do put your toe in the water at the shallow end first - then go deeper . Not jump in the deep end hoping for the best .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
