Re: info - 440 Source balanced kit, 505 update
[Re: 451Mopar]
#1024399
11/22/11 04:27 AM
11/22/11 04:27 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Slotted Cam Trick ????
Sorry, the cam bearings were tight, so I used an old cam with slots cut in it to shave the cam bearings to size. I tried this earlier, but did not clean up the burrs after slotting the cam journals ans it took too much off the bearings, so I cleaned up the slots, de-burring them and this time it did a good job sizing the cam bearings.
I'm not a fan of the slotted cam trick. I like to put some green scotch brite in a slotted mandrel and clean up the bores really good with a die grinder. Then I clean off the leading outside edge of the cam bearings so they start in the cam bores without pulling material and I also take a razor blade and de-bur both inside edges of the cam bearings as I've seen a little bit of an edge that can cause the cam to be tight. I've had fair to good luck doing this. Sometimes though, I've had to use the scotch brite on the inside of the bearings. Not my preferred method, but the cam really does need to turn freely.
Entire Thread
info - 440 Source balanced kit, my measurements.
451Mopar
07/02/11 04:20 PM
Re: info - 440 Source balanced kit, my measurements.
Chris2581
07/02/11 04:25 PM
451Mopar
07/02/11 04:50 PM
Stanton
07/02/11 07:17 PM
steeldust
07/03/11 12:48 AM
451Mopar
07/03/11 08:28 AM
steeldust
07/03/11 01:20 PM
Big Squeeze
07/03/11 04:00 PM
Performance Only
07/03/11 04:20 PM
Big Squeeze
07/03/11 10:06 PM
1_WILD_RT
07/04/11 05:12 AM
Big Squeeze
07/04/11 05:16 AM
kingdust
01/14/12 12:53 AM
451Mopar
01/14/12 06:15 AM
451Mopar
01/14/12 06:30 AM
polyspheric
09/13/12 04:01 PM
BLONDE BARRACUDA
07/03/11 05:29 PM
383man
07/03/11 06:07 PM
DoubleD
07/03/11 06:16 PM
Twostick
07/03/11 09:12 PM
Mick70RR
07/03/11 10:08 PM
383man
07/04/11 01:58 AM
Roughbird72
06/16/18 07:49 PM
451Mopar
07/04/11 06:22 AM
451Mopar
07/04/11 07:16 PM
Thumperdart
07/04/11 08:43 PM
451Mopar
07/05/11 06:57 AM
451Mopar
07/17/11 09:48 PM
Leigh
07/17/11 10:08 PM
451Mopar
07/17/11 10:22 PM
07/17/11 10:24 PM
451Mopar
07/18/11 12:34 AM
FastmOp
07/18/11 03:13 AM
451Mopar
11/21/11 09:58 AM
keelsracing
11/21/11 02:15 PM
451Mopar
11/21/11 04:56 PM
dodgeboy11
11/22/11 08:27 AM
451Mopar
11/22/11 10:55 AM
451Mopar
11/26/11 07:55 AM
451Mopar
01/13/12 07:08 AM
dogdays
01/13/12 05:58 PM
451Mopar
01/13/12 11:54 PM
BDS871Cuda
01/14/12 06:48 AM
451Mopar
01/25/12 05:23 AM
70blackfish
01/25/12 05:31 AM
451Mopar
01/25/12 06:03 AM
smokinwoody
01/25/12 01:22 PM
451Mopar
08/09/12 05:22 AM
mopar400
09/13/12 03:32 PM
451Mopar
06/16/18 06:02 PM
CSK
06/16/18 06:38 PM
