Slotted Cam Trick ????
Sorry, the cam bearings were tight, so I used an old cam with slots cut in it to shave the cam bearings to size. I tried this earlier, but did not clean up the burrs after slotting the cam journals ans it took too much off the bearings, so I cleaned up the slots, de-burring them and this time it did a good job sizing the cam bearings.
