Thx...
Started working on installing the roof rail trim so I could install the 1/4 windows...
About the time I thought I was done fabricating and grinding and welding and priming I found out I was wrong...
1st piece of trim I start to install has the factory clip rotted away and missing...
I check the other side...Yep both are trash...
I have that same piece of trim NOS for my 65 Belvedere II so I dug it out...
Clip was brand new and in tact...
If anyone else needs one the dimensions for this clip are in the pics below...
