So another summer of fun with my completed cars is over... rant
This has been moved back into the upper garage for work to continue...
Plan is to get all of the metal work completed...
Then send it over to a buddies garage to begin bodywork and paint...
I have a lot of work to do with the front end to finish the fenders and get the hood on...
Once that is worked out I need to design any bracing and fabricate all of the latches to get the front end to open and close correctly...
It will be a one piece flip nose front end for ease of working on it later...
Plan is to mock up everything for the engine and transmission again to sort out the brackets for the radiator...throttle linkage and the like...
...FAFO...
