Thx...
I got my Ansen Blowproof Bellhousing back. I sent it out and had it jigged and re-drilled to accept an A833.
(Pic is from before I sent it out)
I picked up a correct 65 bell housing pivot and now need to begin to mock-up the engine and transmission.
I'm using the Z-bar placement as the one spot that everything else will need to revolve around. It's going to be a little while before I have anything concrete as now I have to incorporate the engine-trans with the headers and front cage bar placement while integrating the steering shaft and box placement...
I still need to find a set of used RB fenderwell headers. A,B,E Early B I don't really care...
If something doesn't turn up soon I guess I'll have to order new...
