" I unplug the fuel pump relay & bypass it & LOW & BEHOLD I found melted terminals on the electrical plug"
what gauge wire are you using, and was the terminal connection to the wire a good one ? was the relay a lower amp/parts store relay that may have been part of the melted terminals ?
I used Bosch 30 amp relay & the pigtail is 12G connected to a 10g to go all the way to the tank. the plastic wire holder melted a little around the connectors,
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
