Does the system normally operate at 47psi? In other words....... that’s the system pressure while you’re driving, and just as importantly...... tuning?
I’m sure the melted terminal aren’t a sign that everything was happy.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
