I pulled over to take a picture,, 10,000 miles on this since I put it all together, One engine refresh @ the 5k mark for a bad camshaft & tool steel lifter combination, now a Hydro Roller, so now 5k on this set up, so far so good, just drained the oil & filter change looks very good, clean filter & it had 1kmiles of use.
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
