a question i have wanted to ask, but haven't yet, what would happen if i installed a late model FI can filter [such as a minivan uses in the supply line after the tank] in a carb'd application ? i can't state an exact application, but with the master catalogs i have, i could likely come up with an application that has a 3/8" [or metric equivalent] in and out. this would be for an intank pump [aeromotive 340lph] feeding a tick over 500hp. the reasoning behind this would be "any parts store" availability, along with an economically priced item. thoughts on this ? [TIA ! ]
