Looks like they designed it to be made into MW size.
Yes I called Hilborn before I bought it & they said the max wedge was the same casting as the 440 port. The shadowing in the picture makes it look like I did not follow the contour of the port, but I did.
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
