Well, the NFL draft is close enough to over for me to get back to work!
Cleaned up the mess I made gutting the battery, and cleaned and oiled the tools. I'll start in on cleaning the case later tonight. Was going to call it a morning, then started looking at the mess the engine compartment is. Where to start? EVERYTHING needs cleaning, replacing, work work work.
I thought if I was going to start to work in here, then cleaning up around where the radiator mounts would be the place, before the radiator is re-installed. There were quite a few bent over fins on the condenser (I think the radiator has been in and out once before), so straightening that out and cleaning that area was the thing to do, it seemed.
A few "before" photos of the damaged areas.
The magic radiator comb!
Some of those areas are too bent up for the comb to get through, so I did a little pre-work in spots with a small screwdriver.
Those same two spots "after". Worked pretty darned good, I must say.
After working my way the rest of the way across, blowing it out with compressed air, then brushing it off, it turned out pretty nice. Not bad for 43 years old.
