on a different note, i am swapping out the stamped 727 deep pan for a cast version, which will hopefully stop the leak at the trans. the question is, do i need to add a deeper filter pickup? the old pan has a 1" deeper pickup in it, but the new trans cast pan is about 1" deep than that. do i need to be picking up from the bottom???
