Have you verified your actual water temps compared to what YOUR gauge is saying?
I had one the high dollar Auto Meter mechanical water temp gauges read 40 F higher than the actual water temps where in the car, I found that out at the races when I stuck my hand on the radiator top when the Auto Meter gauge in the car was reading 140 F when the radiator was cool, not hot. I stuck my finger into the coolant circulating from the radiator cap opening and it was not hot, barely body temps
![shock shock](/ubbthreads/images/graemlins/custom/shock.gif)
Murphy hates us hot rodders and racers
![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
AKA, when it doesn't make since there is usually a reason for that
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
