"The shroud is riveted tight to the radiator. I don't think much if any air can escape it"
This may be some of your issues at speed. However, before going down that rabbit hole get it to stay at a constant temp at idle or low/slow speed driving. The electric fan on/off temp needs to be brought down and then see what happens.
