Originally Posted by MR_P_BODY
Not really on either of those issues.. it could reduce some heat.. but on the heat I think you
have another issue.. it could be as simple as the pump not turning fast enough.. do you run
a shroud on the fan.. are the fan blades just in from the edge of the shroud
wave
this is what i am running at this time.
