The Hyperspark is a locked out distributor. All it has inside is a sensor that tells the EFI system what the RPM is and where #1 is. It won't work with your MSD system so you'll need to wait until you install the Sniper before you can install the Hyperspark. The Sniper + Hyperspark is a great combination but you have to add them together.
