Originally Posted By maxfield303H1E
I can't see how the mass backing will make the carpet fit any better.
The mass backing gives the carpet more structure or integrity to maintain it's shape, if you compare it to the "regular" bonded membrane which cracks/breaks when folded, esp in formed areas you'll see that the mass membrane doesn't become damaged when subjected to folds/creases, plus the thicker coating I would suspect offers some extra degree of sound deadening, and moisture resistance as well
