Quote: ok this is probably a stupid question, but what do you do about carpet after you cut the floor all to bit and stretch to stuff the T56 in? can stock carpet be remolded or do you need something different?
I re-used the carpet that was already in the car. It had to re-mold itself back in the footwells a little but its good to go. My cross member was made like it was for this reason, to keep the tunnel height at a minimum.
