Quote:Quote:Quote:what are the details on timing? Best timing is as follows: 24 degrees from idle to 3000rpm, then drop to 20 degrees the rest of the way out. It was a toss up between messing with the idle air bleeds and just adding timing to clean up the low rpm curve. Adding timing was easier and worked great. Steff....are you saying you set the timing at 24 locked in from idle to 3000?Any cooling or cranking issues with that much timing at static?
