Quote:Quote:what are the details on timing? Best timing is as follows: 24 degrees from idle to 3000rpm, then drop to 20 degrees the rest of the way out. It was a toss up between messing with the idle air bleeds and just adding timing to clean up the low rpm curve. Adding timing was easier and worked great.
